Thermal Load
27 REPLIES 27
Message 1 of 28
12363 Views, 27 Replies
Thermal Load
I am trying to apply an 80 degree thermal load to the upper surface of an RC Shell but it won't let me specify a temperature in the "surface > thermal loads" window. I can assign a gradient and apply it to the shell but no temperature.
27 REPLIES 27
Message 21 of 28
Refaat
Hi
I hope this capture also will help you
Refaat
Message 22 of 28
Refaat
in reply to: Refaat
Hi
Gradient / Corrected
Refaat
Message 23 of 28
in reply to: Refaat
Thank you for your answer. I have just a last question. If the gradient is the diffrence between top an bottom for example if T1 = 40° and T2 = 10° C. How to estimate de initial temperature (assembilng temp) ?
Message 24 of 28
Rafal.Gaweda
Initial temp is temperature let say on site while assembling \ building structure.
Rafal Gaweda
Message 25 of 28
in reply to: Rafal.Gaweda
ok ! thanks
Message 26 of 28
in reply to: Refaat
salut,
je veut juste savoir comment on calcul le gradient et comment l'introduire dans RSA?
et c quoi le gradient et c quoi le dt1 ?  et merci
salutations
Message 27 of 28
patrick.emin
Hi @Anonymous we have a forum in french : Robot Structural Analysis - Discussion en français
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
Message 28 of 28
Initial  temp. = 20 c
(Maximum temperature )Summer temp. = + 45 c
(Minimum temperature )Winter temp. = - 5 c
Minimum thermal gradient ,ΔT= (-5-20) = -25 c
Maximum thermal gradient ,ΔT=(45-20) = + 25 c
The meaning of "gradient" in robot temp panel load is the temp difference between top and bottom layers of panel (difference along panel thickness)
so in your case(s) (I understood the whole panel has the temp +45 or -5 along thickness)
1. Summer : load window setings : Temperature = +25, Gradient = 0.
1. Winter :  load window setings : Temperature = -25, Gradient = 0.
Hi dear@
i need to know, if i understand in this case :
in summer dt =+5°c   not +25°C.
in winter dt=+5°c   not      -25°C  .
because assembling temperature is 20°c so :
in summer 45-20-20=5°c
in winter -5-20+20=-5°C
its correct or not?
thank you.
