the map results doesn't show
Salman-2550
Message 1 of 8
Salman-2550
I exported the model from Revit to robot. but for some reason, the maps results are not showing. I tried everything but yet nothing works. the rest of the results are fine because of course I applied loads in revit
Replies (7)
Message 2 of 8
Refaat
Hi @Salman-2550
It seems the story is hidden. Try to activate it by pressing on ( Filter stories option ). If doesn’t work, Share the model.
Message 3 of 8
Salman-2550
Hi, thanks for your feedback! I tried it but still doesn't work 😞
Here's the file! if you found something please let me know
thanks again!
https://drive.google.com/file/d/1JXtQrQTifS4-63pVW2MnmuY-sY8OEUeV/view?usp=sharing
Message 4 of 8
Refaat
Hi @Salman-2550
The slab thickness is missing.
Message 5 of 8
Salman-2550
How do I add it?
Message 6 of 8
Refaat
Hi @Salman-2550
To define the slab thickness.
If you want to align the top of the beams with the slab then draw the beams at the same level of the slab then the offset option can be used.
To view the action of the offset option.
Then the analysis results.
Message 7 of 8
Salman-2550
it worked!!
Thanks a lot
Message 8 of 8
3336230061
I've followed the steps but its still not showing
