The difference between planar spring support and elastic foundation coefficient
Hi Autodesk Support Team.
Could you let me know the different between planar spring support for plate and elastic foundation coefficient  ? If I assign only foundation coefficient for slab, I can get soil pressure but when I active displacement too big as picture below :
Displacement-u,w in Detailed tabs:
So which one is correct ?? Do my analysis is correct when I have no support warning after run analysis.
@Anonymous Artur Kosakowski edited the topic from 'Soil Spring For Mat Foundation ? ' for better findability
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Please check this topic.
Artur Kosakowski
mustafahesenow
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I just wanted to ask if we managed to answer your question and if yes ask you to mark the best answer as the solution so that it can be easier to find for other. Thank you.
Artur Kosakowski
