Quick Model Check
Quick Model Check
Quick Model Check
I am using Robot for the very first time on a current project and I think I have managed to build a basic model (looks ok anyway!).
It is a 9 storey concrete building with flat slabs sat on blade columns, with lateral stability gained via shear walls.
I have applied floor loading to each level and generated the combinations, however I have a warning which states 'the load has not been distributed correctly - there are no objects or elements carrying the load overlap' and im not sure how to solve it.
could I ask if anyone has a spare few minutes could they quickly interrogate my model to see if I have assembled things correctly?
I will also be seeking advice regarding running the analysis too.
Cheers.
Ant
mustafahesenow
Hi @Anonymous
Send us the model please .
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
