Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
353 Views, 4 Replies
THA Wind Load
Hello, I would like to check the deformation results obtained in my model (attached), considering a THA for the wind load applied in horizontal direction.
I set the function "viento_0.01Hz" is sin(360*f*t), where f(frequency) is 0.01 Hz according to standard wind.
I obtein less deformation in THA mode than in a static linear mode for the wind load.
Please, someone how indicates if the results are correct or not.
Thanks.
4 REPLIES 4
Simau
@Anonymous
Could you please tell us what is the meaning of cases 2 3 4 ?
M. Agayr
Krzysztof_Wasik
Hi @Anonymous
Your THA analysis lasts 10 s. According to your THA function value =0.59 for t=10 s
Load changes very slow (small frequency) so loads acts as quasi static. If you increase THA time to 25 sec. you should reach THA function value =1 so results for load case 3 should be similar to THA results in last time step.
Krzysztof Wasik
in reply to: Krzysztof_Wasik
Thank you Krzysztof.
Ignacio Domínguez.
in reply to: Simau
Hellow Simau
Case 2: aditional weights loads
Case 3: wind
Case 4: snow
Thank you for helping.
Ignacio Domínguez
