Tension in column
Tension in column
Tension in column
please let someone explain to me how I should solve this problem as soon as possible. see attachment
hi guys
can someone explain to me how I should solve this problem. see attachment.
Artur.Kosakowski
Autodesk Support
Autodesk Support
This is not a problem but just the information that some of load cases caused tension force in the column. The intention was for a stand alone module when (especially a new Robot user) accidentally defines load with the opposite sign.
Artur Kosakowski
thanks. but could you please explain to me what to do?
Artur.Kosakowski
Autodesk Support
Autodesk Support
If the tension force is justified (it is one of the load scenarios you expect) then just ignore this message as the calculated reinforcement is capable of transfer it (and the warning is just informative). If there should not be any tension force in the column then check the applied loads or results of the static analysis of the model to determine why this happened.
Artur Kosakowski
