Structural analysis- EC8 reduced moment of inertia
Hi, everyone.
I 'm trying to apply reduced moment of inertia according to EC8 par. 4.3.1 (7) to a building model. I have a lot of load cases (additional permanent loads, live loads and seismic load) and I have concluded that the best way to do so is to create a new material with reduced E modulus by half. The question is at what point of the structural analysis do I have to apply this new material, since all static loads should be calculated with the characteristics of uncracked section.
teixeiranh
I would say that for ULS use the cracked section properties. For SLS it depends.
“The most powerful force on the universe is compound interest.”
Subscribe me on Youtube:
https://www.youtube.com/channel/UC6G8OOp318Z1MFzJj5T8uWw
StefanoPasquini6790
Hi everyone,
My assumption is that the reduced moment of inertia should be applied "only" in seismic cases for uls.
Greetings
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Hi StefanoPasquini6790,
I totally agree with you, but the problem is that I dont know how to do it in Robot, since if I define a material with a reduced E-modulus, this defintion will be taken into account also in all load cases. Is there any way run static load cases with E-modulus and seismic load cases with a reduced E-modulus?
Thanks in advance
StefanoPasquini6790
HI
the answer is "two different models", one for seismic condition and one for standard ULS conditions.
PasProStudio
so you mean that I will create two similar models with members with different E-modulus, get results and design rc members. Hence, I have to combine the two analysis in order to get the most unfavorable reinforcement. Is this the "proper" procedure because even for a small structure this will lead to a massive amount of work?
