Stress for a wood cross section won't show up
5 REPLIES 5
439 Views, 5 Replies
As shown in picture 1 I have created this kind of column, with a variable cross section, larger at the top and smaller at the bottom, when looking for the results of the stresses inside the cross section, Robot will give an error, saying that parameters for the cross section are not given. For all the other standard cross sections of the structure I have no problem, and all the parameters for all the elements are stated correctly. Any suggestions on what the problem might be?
Thank you.
5 REPLIES 5
Rafacascudo
Looks good to me.
where exactly are you having problems?
Zip and attach the model ,if possible
Rafael Medeiros
in reply to: Rafacascudo
I can see that, I cant see it from here. (the screenshot is in Italian, hope you can understand of what kind of result I am talking about)cross.PNG
Rafacascudo
Not working here too for any tapered sections. Maybe official autodesk support has an answer to this problem
@Rafal.Gaweda @Artur.Kosakowski
Rafael Medeiros
Hi @Anonymous
@Rafacascudo is right. Tapered sections are not supported (recognized) by the stress analysis module.
Artur Kosakowski
in reply to: Artur.Kosakowski
thank you both.
Technology Administrators
