str import error
str import error
Message 1 of 11
str import error
I save an available model to file of str format, which cannot be opened.
errors and warnings are shown below, it seems that the parameters of profile are not recognized well.
Both rtd and str file are attached.
How should I correct .str file.
I used a Chinese version of Robot to establish the model, does it matters when using .str file saving?
Replies (10)
Message 2 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Is it the same when you replace '.' (dots) with ',' (commas) in the str file?
Artur Kosakowski
Message 3 of 11
It didn't help when I replace dot with comma, anyway thanks.
Message 4 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you send me screen captures from
Preferences > languages
Job Preferences > materials
Job Preferences > Databases > Steel and timber sections
from your Robot?
Artur Kosakowski
Message 5 of 11
I've switch the working and printout language to English. I do tried to open str.file  and failed again. It seems that material C35 is fine. Maybe just the problem of profile section in database.
preference_language.JPGjob_preference-materials.JPGjob_preference_materials_concrete.JPGjob_preference_databse_steel.JPG
Message 6 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Try these steps:
Artur Kosakowski
Message 7 of 11
I deleted two database, and str.file could be opened. After redefinition  of material, calculation could be conduct.
Thank u. ^_^
Message 8 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I'm glad it worked for you Smiley Happy
Artur Kosakowski
Message 9 of 11
Hy,
I have the same problem with eurocode
2017-12-30 00_17_08-Autodesk Robot Structural Analysis Professional 2017 - [Vue].jpg2017-12-30 00_17_39-Autodesk Robot Structural Analysis Professional 2017 - [Vue].jpg2017-12-30 00_17_58-Préférences de la tâche.jpg
Message 10 of 11
try to delete the EUR code form database and run the script file
Message 11 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Try to add ACIER to the list of Eurocode materials or change materials to French. If this doesn't help attach your str file.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
