steel plate design
steel plate design
Message 1 of 10
steel plate design
hi
i have steel plate with dim 0.7m*1m and one nodal force in center of this plate how can i design thickness of this plate?
regards
Replies (9)
Message 2 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
You may try to check von Mises stress value and compare it with the limit one.
Artur Kosakowski
Message 3 of 10
dear artur
thanks for your good guide.please if its possible explain it that  how to compare?my result is attach
regards
Message 4 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
Compare the value of stress from the map with the resistance of the steel grade you used as a material of the plate.
Artur Kosakowski
Message 5 of 10
dear arture
thanks for your guide
Message 6 of 10
I have a question regarding a similar plate, but it’s a topplate for a pile. To design this plate I have modelled a planar fixed support under the plate to indicate the pile. When you use von mises stress value, does is it take into account the thickness of the plate and the distribution of the support reaction to the center of the plate?
Or do I have to model a bigger support to take into account the distribution of the load?
I hope the drawing above explanes my question better.
Message 7 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
Mind that a shell doesn't have 'real' thickness which is just its attribute (as a profile for a bar element). If so you either need to increase the size of the support or decide to use a solid model instead.
Artur Kosakowski
Message 8 of 10
Thank you, Artur!
Message 9 of 10
me1205377
Greetings , just wanted to know if this method is used is there a need to  compare the stresses with the yielding stress multiplied by a reduction factor
for example 0.9* fy or 0.75 fy ?
moustafa elgaar
Message 10 of 10
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @me1205377
Yes, with whatever limit (including safety/material factors) which is applicable for the particular design you are performing.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
