Export to dwg
Export to dwg
Export to dwg
Is there a way to export a model to dwg? (is a bar/nodes model. No surfaces, objets...)
Actually I just need to export the supports nodes (obviously I also need in the drawing node's numbers).
Rafal.Gaweda
Autodesk Support
Autodesk Support
File \ Save as (*.dwg or *.dxf)
Rafal Gaweda
I get a dwg with lots of layers (from R000 to R255) but only layer R025 has information (node numbers).
I'd also need the points.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Nodes \ points are not exported to dwg
Rafal Gaweda
