12:48 AM
Dear All,
when using the steel design module, you can select the number of calculation points (either evenly distributed or some characteristic points of interest e.g. max bending, etc.).
I have selected 5 calculation points, evenly distributed. Is it correct to assume that Robot will check the steel element in only those five points?
I am a little confused because doing a check on an element it seems it's considering a different section to the ones I have selected (indicated in point/coordinate)? what does this line Point/Coordinate indicate? is it the section that it's driving the design?
