Cursor and Values Missing
Cursor and values next to it of Moments I have the map set to display are missing. Get Blue dash or three dots instead. Means I can't add descriptions (indicate graphically) to display on my maps or see the values at any point.
Could some explain whats going on?
Cheers
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you attach a screen capture which shows what you described please? Thank you.
Artur Kosakowski
The Blue dots next to the maps box is where my mouse was.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to press the indicated button and try again. If this doesn't help save the file and open it again.
Artur Kosakowski
That worked for the view I was in but when I reverted to full view it has reverted to not working and the button is not helping
Figured it out, It doesn't allow me to add values when showing panel cuts.
Otherwise the button indicated works thanks.
