RC Column Design with Non Linear analysis results
I want to design an RC column under EC2 wihout taking into account the simplified second order analysis methods in the design process, since I have already performed a second order analysis in the model. Is there a way to disengage that part of the design process in the Provided Reinforcement calculation options of the column module?
Best Regards,
Charis
Artur.Kosakowski
Autodesk Support
Autodesk Support
The only way would be to set X for coefficients of both buckling directions.
Artur Kosakowski
