Meshing problem while circular wall joining rectangular base
I have modelled the rectangular base and added circular opening same size as the wall and then added the another circular panel to complete the base. Then modelled the vertical circular walls as objects. there is also a vertical central wall modelled and this wall is detached from the circular wall.
While meshing the whole structure there are meshes created in circular base are as shown in attachement 1. can anyone help me to resolve this.
i have tried to discrete the circle also, but it was not help full.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hope this helps.
Artur Kosakowski
Thanks rafal, i had tried it before but with different no of edges so it wasn't working for me.
Can you tell me how did you got 72?.
i have discretized both circular portion of slab and circular wall. I got some incoherent edges, but ther were only 2 nodes, so i have adjusted the nodes. it worked for me, thanks a lot.
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'm not sure what you mean. Is it why 72 rather than any other number?
If yes, that was just "random" value I entered. In case you need to move some nodes to make coherent meshes see the recording of the 2nd Robot webinar.
Artur Kosakowski
