different results between CBS and ROBOT
I've exported a building from cbs to robot but i dont find the same results .the support reactions are different between cbs and robot . See pictures attached. Pleeeease could somone explain to me . Thanks.
Regards
difference of 200 KN ??? that's a lot
Artur.Kosakowski
Autodesk Support
Autodesk Support
Try to calculate Robot file assuming thickness of all slabs being 1 cm.
Artur Kosakowski
But If I assume the thikness of slabs being 1 cm, the reactions due to the self weight will be wrong.
Artur.Kosakowski
Autodesk Support
Autodesk Support
The aim of this test is to check how much of the difference you mentioned is caused by using the load takedown approach vs. distribution of load based on stiffness of elements of a model. I believe that you can replace automatically generated self weight with the surface loads corresponding to the real thicknesses of slabs. Otherwise you may create new materials with appropriately scaled density.
Artur Kosakowski
Exporting maybe is the culprit. try creating  a whole new project in robot. then compare the reactions...
