Steel design report
5 REPLIES 5
polylouis
453 Views, 5 Replies
Steel design report
Hello eveyrone,
Do you know a way with the API to save the report of steel design (especially for some resultats like ratio and forces calculted for it) ?
The most will be to save in a document the following image :
Thank you in advance,
Regards
Louis
@Rafal.Gaweda if you know useful tips it will be great !
5 REPLIES 5
polylouis
in reply to: polylouis
Hi @Stephane.kapetanovic
thank you for the reply !
But I don't know how to use this code line in the correct way (especially for RdmStream and the way of calling)
Do you know more about it ?
Regards
HI @polylouis
Sub CreateSteelReportSaveAsRTF()
  Dim RobApp As IRobotApplication
  Set RobApp = New RobotApplication
  Visible = RobApp.Visible = -1
  IsActive = RobApp.Project.IsActive = -1
  Ready = Visible And IsActive
  If Not Ready Then
    Set RobApp = Nothing: Exit Sub
  End If
  Dim RDMServer As IRDimServer
  Dim RDmEngine As IRDimCalcEngine
  Dim RDmCalPar As IRDimCalcParam
  Dim RDmCalCnf As IRDimCalcConf
  Dim RdmStream As RDimStream
  Dim DimAllRes As IRDimAllRes
  Dim OutputFile As String
  OutputFile = "my_note_file_name_001.rtf"
  With RobApp.Kernel.GetExtension("RDimServer")
    .Mode = I_DSM_STEEL
    Set RdmStream = .Connection.GetStream
    Set RDmEngine = .CalculEngine
    With RDmEngine
      Set RDmCalPar = .GetCalcParam: .SetCalcParam RDmCalPar
      Set RDmCalCnf = .GetCalcConf:  .SetCalcConf RDmCalCnf
    End With
  End With
  RdmStream.Clear
  RdmStream.WriteText "3" '...............................Set Load Case(s)
  RDmCalPar.GetUlsLoadsList RdmStream
  RDmCalPar.SetLimitState I_DCPLST_ULTIMATE, 1 '..........Set Limit State
  RdmStream.Clear
  RdmStream.WriteText "1to3" ' ...........................Member(s) selection
  RDmCalPar.SetObjsList I_DCPVT_MEMBERS_VERIF, RdmStream 'Members verification
  RDmEngine.Solve Nothing
  Set DimAllRes = RDmEngine.Results
  DimAllRes.MakeNote RdmStream, "", OutputFile
End Sub
Best Regards
IRobotApplication RobApp = new RobotApplication();
bool isVisible = RobApp.Visible == -1,
      IsActive = RobApp.Project.IsActive == -1,
         Ready = isVisible && IsActive;
if (!Ready) { RobApp = null; return; }
RobotAppKernel Kernel = RobApp.Kernel;
IRDimServer RDMServer = Kernel.GetExtension("RDimServer");
RDMServer.Mode = IRDimServerMode.I_DSM_STEEL;
RDimStream RdmStream = RDMServer.Connection.GetStream();
IRDimCalcEngine RDmEngine = RDMServer.CalculEngine;
IRDimCalcParam RDmCalPar = RDmEngine.GetCalcParam(); RDmEngine.SetCalcParam(RDmCalPar);
IRDimCalcConf RDmCalCnf = RDmEngine.GetCalcConf(); RDmEngine.SetCalcConf(RDmCalCnf);
RdmStream.Clear();
RdmStream.WriteText("3");    // ULS Load Case(s)
RDmCalPar.SetUlsLoadsList(RdmStream);
RdmStream.Clear();
RdmStream.WriteText("1to3"); // Member(s) selection
RDmCalPar.SetObjsList(IRDimCalcParamVerifType.I_DCPVT_MEMBERS_VERIF, RdmStream);
RDmCalPar.SetLimitState(IRDimCalcParamLimitStateType.I_DCPLST_ULTIMATE, 1);      // Set Limit State
RDmEngine.Solve(null);
IRDimAllRes DimAllRes = RDmEngine.Results();
DimAllRes.MakeNote(RdmStream, "", "my_note_file_name_00.rtf"); // Save in RTF
RobApp = null;
polylouis
@Stephane.kapetanovic thank you a lot !!!
Technology Administrators
