I am developing my own tools to check steel profiles using the Robot Steel API (C#).
To export these results in a doc or rtf file, I use the IRDimAllRes.MakeNote(IRDimStream, rtf file, out file) .
Evreything is fine, but I would like to create also my own rtf templates.
Is there somewhere a list of available robot variables and names that can be used in rtf templates ?
Thanks for the answer(s)
Bonjour,
Le IRDimAllRes.MakeNote créé un fichier par défaut sous : "C:\Users\Nomutilisateur\Documents\Autodesk\Output\Nomdufichier".
A partir de là, je renomme le fichier et le modifie comme je veux en créant des sauts de pages automatiques par exemple.
Cordialement.
Thanks for the tips, but it does not answer the question: what are the available variables to be used in rtf files ?
Otherwise, using C#, I do prefer to produce a docx report including exactly what I want to be inside
Regards
Nioul
check such rtf ; as far as I remember all variables are between @....@
Hi Rafal,
yes, you are right, for example @Anonymous(MomMfyrd@ or @Anonymous(LatBT=LatBuckType0)@ ....
But is it possible to find somewhere a list of all available variables with their names ?
Regards
Hi everyone,
Could you please help me to have a correct way to use MakeNote ?
I tried but no file test.rtf created :
rDimAllRes.MakeNote(obj_list: (RDimStream)rDimStream, rtf_file: "C:\\Users\\lxxx\\Documents\\Rsec.rtf", out_file: "C:\\Users\\lxxx\\Documents\\test.rtf");
Thank you in advance,
Louis
