Steel Design Calculation Points
Hello Everyone
How can I see the steel design calculation for each calculation point inside the robot ?
Currently I use a micro showing the steel design ratio for each calculation point which is shown in the screenshot.
the problem here is the steel design ratio is different as you can see in the image, actually the ratio from the macro is much correct than what is robot showing in the dialog.
When I use characteristic points - Max My then the result becomes true and similar to the macro.
Why Robot gives a wrong ratio even if I use 10 calculation points for a simply supported beam ??
Thanks for answering...
