RSA Not showing the Beams Parameters Dialog box when in the beam design module
james.mahinda-edvik
Message 1 of 9
james.mahinda-edvik
I am trying to design RC beams in RSA 2024 version.
After selecting the beam for RC member design, RSA should pop up the dialog box for Beams-Parameters of RC elements so that I can define the supports, etc. (See snippet below)
However, this is not happening. Anyone who can provide a solution on this?
Replies (8)
Message 2 of 9
JohanDuPlessis
Hi @james.mahinda-edvik,
You can open it from the Analysis menu.
I hope it helps.
Message 3 of 9
james.mahinda-edvik
@JohanDuPlessis Where do you define the supports?
Message 4 of 9
JohanDuPlessis
That is done in Span Geometry at the bottom of the screen.
Message 5 of 9
james.mahinda-edvik
@JohanDuPlessis May be I was not clear. In the dialog below, you are able to select which member is a support to the beam, especially in a case where two beams are crossing each other. How do I retrieve this dialog box?
Message 6 of 9
JohanDuPlessis
Oh, sorry, I misunderstood you.
Try this:
  1. Select the desired beam in the model
  2. Go to Design > Provided Reinforcement of RC Elements
Message 7 of 9
james.mahinda-edvik
@JohanDuPlessis When I do that, RSA is not popping up that dialog box. That is my issue.
Message 8 of 9
JohanDuPlessis
Try running required reinforcement calculation first.
Message 9 of 9
okapawal
What is the design code you are using?
And how is your beam supported in the model, by columns, walls or beams?  Give at least a screenshot.
Waldemar Okapa
Sr Product Owner
