Steel Connection Design
Hello there, I have some problem regarding steel connection design using channel section. Why i cannot choose channel section (i.e RSC 152 x 76) for the steel connection design in my model, is there any problem with the section i used? I have attached my model here. Thank you.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Channels are not supported for this connection type in Robot.
Artur Kosakowski
Thank you Mr.Artur.
