Steel Connection Design Report - Weakest Component
I've modelled a simple shed structure as shown in the snap.
I am trying to design the structural steel connections.
The reports for all the connections says "connection confirms to the code".
However, for the "Fixed Column Base" and "Frame knee" connections, I get a statement at the end of the report with the heading "Weakest Component".
For "Fixed Column Base" - Weakest component: FOUNDATION - CONCRETE SPLITTING
For "Frame Knee" - Weakest component: COLUMN WEB PANEL - SHEAR
Attaching a sample design report (Column-Base) exported from Robot.
Is this just a warning? Or something that I should worry about?
Do I need to change something in the structure?
P.S:
1. "Beam-Column (web)" connection doesn't show the "Weakest component".
2. I am new to Robot and am a learner still 🙂
teixeiranh
It is a warning and you should take it into account.
A steel connection should have a ductile mode of failure.
You should avoid having you "weakest component" associated with a brittle mode of failure.
For example, if you have a Fin Plate connection resisting shear your "weakest component" should not be the bolts, but the plate.
With this being said, you should, of course, always have a ratio less than 1. Ratios less than 1 and ductile connections, that is your objective.
“The most powerful force on the universe is compound interest.”
Subscribe me on Youtube:
https://www.youtube.com/channel/UC6G8OOp318Z1MFzJj5T8uWw
Hi Teixeiranh,
Thanks for the prompt response.
However, If there is a brittle failure, then I should see in report messages like "not OK" or "Connection does not conform to code".
Right?
Moreover, in all the connections in my structure the ratio is less than 1 (hence "OK").; but the statement about "Weakest component" is regarding concrete splitting in all the cases.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
It is just the information which verification check gives the highest ratio. As long as all of them are below 1 the connection is OK.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
