AISC/ASCE bolted connection verification
EnricoCorvaglia
EnricoCorvaglia
Hi
I'm doing a bolted structure in RSA in accordance to following codes:
- AISC360
- ASCE 7-05
- ANSI341
How can i verifie bolt connection? when i select code for steel connection i see only codes in the screenshot. Where are USA codes?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @EnricoCorvaglia
The US codes are not supported in the steel connection module of Robot Smiley Sad
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
EnricoCorvaglia
The US codes are not supported because EC3 connection method is more restrictive of 341/358 method? can I answer so to the client's comments? or US codes are not supported for other reason?
thank you for replay
EnricoCorvaglia
EC3/EC8
StefanoPasquini6790
Hi Italo,
Unfortunately Robot don't support steel connection for America design codes, because they are not yet implemented. EC8 verification are not implemented in Robot for connections.
If you need to perform steel connection design with American standard, I can suggest you to use advance steel. You can transfer your model from Robot to advance steel with all the calculation results (it require a lot of time) and then, in advance steel you can define your connection (geometrical parameters) and then run the design checks.
The result report is not so sexy such as the robot one, but it cover a lot of steel connection type, much more then Robot.
One suggestion: if you need to have the report in English, or another language, you have to install the right language pack.
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
ar2851
