- Mute
- Permalink
- Report
I've modelled a simple shed structure as shown in the snap.
I am trying to design the structural steel connections.
The reports for all the connections says "connection confirms to the code".
However, for the "Fixed Column Base" and "Frame knee" connections, I get a statement at the end of the report with the heading "Weakest Component".
For "Fixed Column Base" - Weakest component: FOUNDATION - CONCRETE SPLITTING
For "Frame Knee" - Weakest component: COLUMN WEB PANEL - SHEAR
Attaching a sample design report (Column-Base) exported from Robot.
Is this just a warning? Or something that I should worry about?
Do I need to change something in the structure?
P.S:
1. "Beam-Column (web)" connection doesn't show the "Weakest component".
2. I am new to Robot and am a learner still 🙂
