Steel connection design error message
22 REPLIES 22
Message 1 of 23
4605 Views, 22 Replies
I am trying to use the steel connection design part of Robot to design some primary beam to secondary beam connections but I get the following error message when I select particular beams:
"Number of detected common nodes: 1
Number of created connections: 0
Remarks:
- program is unable to define connections for the current code: 1"
What does this error message mean?
Not all the connections in my model give me this message.. What are the requirements for Robot to be able to carry out the design? Would releases upset it?
Any help would be much appreciated!
22 REPLIES 22
Message 2 of 23
Artur.Kosakowski
Program checks section types and the positions of bars with respect to each other. They have to meet the requirements of the particular connection type.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 23
in reply to: Artur.Kosakowski
Thanks! Is there a way to take a look at the requirements for each connection type?
I want to create beam-beam connections at both ends of a few of my beams and for each beam I get the error message on one end and it works fine for the other end. Seems quite strange!
Message 4 of 23
Artur.Kosakowski
Could you attach the rtd file with the model and indicate the bars you want to create a connection between?
Artur Kosakowski
Message 5 of 23
My model should be attached. The connections I am having problems with are at the ends of beams 7, 8, 10 and 11. They will happily connect at one end but not the other.
Is it something to do with my releases maybe?
Message 6 of 23
Artur.Kosakowski
The beams have to be exactly perpendicular. Try the attached model.
Artur Kosakowski
Message 7 of 23
That explains it, thanks!
Does Robot have any built-in features for checking geometric problems like this?
Many thanks,
Freya
Message 8 of 23
Artur.Kosakowski
No, it hasn't but in RSA 2016 the geometry "inaccuracy" tolerance is increased so that the connections would be created in your original model as well.
Artur Kosakowski
Message 9 of 23
Hello every one , in consideration to previous answer , what is about sloped beams which are connected to columns such as rafters are connected to columns for example in hangars ?  how can solve this problem in this case ?? . Actually I am facing this problem , I can't find exact solution for . Pls can you help me  ?
                            regard
Message 10 of 23
Artur.Kosakowski
Hi @Anonymous
Could you attach sketches of the intended connection?
Artur Kosakowski
Message 11 of 23
Sure, Pls attach considered file. It acts an approximated example
Message 12 of 23
Artur.Kosakowski
Hi @Anonymous
Thank you for the file but could you also attach some drawings showing what types of connections you would like to create?
Artur Kosakowski
Message 13 of 23
rDear Mr Artur.Kosakowski ,
the type of connection that I want to create is shown in the following image, so please attach it
(the main problem is that programme doesn't allow me to create a connection between sloped beams on the roof and columns  which are connected with).
Message 14 of 23
Artur.Kosakowski
Hi @Anonymous
The reason is that you want to connect the rafter with the column web and such connection type is not available in Robot.
Artur Kosakowski
Message 15 of 23
what is about the following image?  It is shown sloped beam connected to column flange-to-flange, but the error message still to appear  !!!
you can review the Upper ROBOT file which I sent.
In the same context, how can we solve the previous problem (rafter connected to column web) ?? This status is possible to appear in various projects. For importance, sometimes we have to connect beams to columns webs.
        Regards
Message 16 of 23
Artur.Kosakowski
Hi @Anonymous,
I can't see any issue
As such connection type is not supported in Robot you either need to design it in another application or by hand.
Artur Kosakowski
Message 17 of 23
Hi Mr Artur Kosakowski,
If you can, please attach related video
Message 18 of 23
Artur.Kosakowski
Hi @Anonymous
You need to select (two) bars you want to generate the interconnection for before you press the connection generation button Smiley Wink
Artur Kosakowski
Message 19 of 23
Sorry but I can't understand you exactlySmiley Sad
as it is shown in the related video, I selected two elements I want to connect which other but no connection is generated
Pls, can you explain your opinion by short video?
Message 20 of 23
Artur.Kosakowski
Here you are:
Artur Kosakowski
