Hi there,
I'm trying to generate connections for all members and columns, however i seem to be having issues with what the software generates.
When i highlight everything, it only creates connectiona for the columns that have supports, but then when i highlight smaller groups of beams, it ends up generating the connections.
It also seems to only generate a frame knee randomly when i select the correct columns and members with a bunch of other ones or most of the time it just doesn't generate anything when i only select the correct ones.
Please let me know what i can do to fix this, i've attached a video, with the beginning being me highlighting everything, then i highlight small groups of beams and columns to show what it generates, then finally i select a beam and a column to create a frame knee which it doesn't do.
Note: In the video there is a box that comes up when i try generate the selected beams that says:
"Program is unable to define connections for the current code: 8" when i selected a group of members and columns.
and
"Program is unable to define connections for the current code: 2" when i select the members and columns to create a frame knee.
Kind Regards.
