Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Spread footing - minimum reinforcement expression
5 REPLIES 5
Mirko.Jurcevic
843 Views, 5 Replies
For my spread footing, Robot calculates minimum reinforcement as:
4,17cm2/m' for bottom zone, and 3,14cm'/m' for top.
According to EN 1992-1-1, this values should be calculated as:
As,min = 0.0013⋅bt⋅d = 0.0013⋅100⋅44 = 5.72 cm2
or
As,min = 0.26⋅(fctm/fyk)⋅bt⋅d = 0.26⋅0.22/50.00⋅100⋅44 = 5.03 cm2
whichever is greater.
Question is simple: Which expression Robot uses to calculate minimum reinforcement of the spread footing?
Same question here (a week ago):
http://forums.autodesk.com/t5/Robot-Structural-Analysis/minimum-reinforcement-of-foundation/td-p/306...
but it seems nobody saw it.
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
5 REPLIES 5
It is being checked.
I will let you know asap.
Rafal Gaweda
Thanks Rafal.
Mirko Jurcevic
2015 Results
Rafal Gaweda
Ok,
it seems that Robot 2015 got it right (for C20/25 and d=43cm)
As,min = 0.0013⋅bt⋅d = 0.0013⋅100⋅43 = 5.59 cm2
But what's with 2014 version users?
Mirko Jurcevic
And what's with that bending moment, minimal reinforcement is not relevant in that case, look, for bigger bending moment:
Design value of concrete compressive strength:
fcd = αcc⋅fck/γC = 1.00⋅2/1.5 = 1.33 kN/cm2
Design yield strength of reinforcement:
fyd = fyk/γS = 50/1.15 = 43.48 kN/cm2
Effective depth of a cross-section:
d = h - d1 = 50 - 7 = 43 cm
Value of nondimensional bending moment:
μEd = MEd/(b⋅d⋅fcd) = 17250/(100⋅432⋅1.33) = 0.070
For:   μRd = 0.070
εc = 2.3 ‰         εs1 = 20.0 ‰         ξ = 0.103         ζ = 0.960
Required reinforcement:
As1 = MEd / (fyd⋅ζ⋅d) = 17250 / (43.48⋅0.960⋅43) = 9.61 cm2
As1 = 9.61 cm2
Minimum reinforcement:
Maximum reinforcement:
As,max = 0.04⋅b⋅h = 0.04⋅100⋅50 = 200.00 cm2
As,min = 5.59 cm2 < As1 = 9.61 cm2 < Amax = 200.00 cm2
Relevant required reinforcement:
As,req = 9.61 cm2
Mirko Jurcevic
