Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
minimum reinforcement of foundation
5 REPLIES 5
3073 Views, 5 Replies
Hi everyone,
I would like to Know how what is the expression of Eurocode, that the Robot use to calculate the minimum reinforcement of the foundation.
Thank you, best regards:
Ricardo Moreira (Portugal)
Edited by
Discussion_Admin
Tags (1)
5 REPLIES 5
GabrieleNovembri1027
I don't know what  kind of criterion Robot uses but Eurocode 8 prescribes minimum reinforcement only for beams and not for the footings for which local ductility is not required. See attached Page.
Tags (1)
If the results from the minimum value that the answer is as follows:
We accept that the elements are reinforced ones.
Due to the limitation of damage to fragile bent elements the condition (9.2.1.1-beams, 9.3.1.1 - boards) is always used:
AsMin = 0.26 * (fctm / fyk) * b * d
When grown fck then fctm grows too.
Also the minimum reinforcement grows with it.
Jakub Brożonowicz
Global Product Support
in reply to: Jakub.Brozonowicz
Thank you,
 When we define a load in "RC_Foundation design" with nature of design the programm don't use this expression "AsMin = 0.26 * (fctm / fyk) * b * d" to calculate the minimum reinforcement. It´s possible to change it ?
Best Regards:
Ricardo Moreira
Jakub.Brozonowicz
This condition is SLS oriented one.
In case of Design load only ULS state check is done and other formulas taken as reference.
Jakub Brożonowicz
I don't understand this answer, and I have similar problem.
For my spread footing, Robot calculates minimum reinforcement as 4,17cm2/m' for bottom zone, and 3,14cm'/m' for top.
According to EN 1992-1-1, this values should be calculated as:
As,min = 0.0013⋅bt⋅d = 0.0013⋅100⋅44 = 5.72 cm2
or
As,min = 0.26⋅(fctm/fyk)⋅bt⋅d = 0.26⋅0.22/50.00⋅100⋅44 = 5.03 cm2
whichever is greater.
Question is simple: Which expression Robot uses to calculate minimum reinforcement of the spread footing?
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
