Specify steel members colour
Good Morning Everyone,
I am currently designing a steel sculpture comprising of square hollow sections (SHS) which spans approximately 28m. As the sculpture has non uniform alignment and weaving through each other, it is easier to tag them with colours (Refer attached screen print). The colour names are already assigned by Architects as per the legend text on the attached screen print.
Is there any way that I can control colours of the steel members to match the colour nominate on legend text.
Thank you,
Raju
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Hi Artur,
Thank you for your help. I had looked into this option before posting on this forum. I was under impression that i would not be able to have separete colours for same sizes steel as all the steel works in the models are of same sizes. Now i knew that i can have the same section size but different labels associated with different colour steel.
Thank you,
Raju
