Unknown run-time error when integrating Revit 2016 to Robot 2016
gustavo_c_vasconcellos
Message 1 of 17
Dear support,
I am receiving the "unknown run-time error" when integrating Revit 2016 to Robot 2016.
This error message appeared after instaling the RSAPRO2016_X64 SP4.
This problem appears in any project, I had already tried to change Robot language (from Portuguese to English), create new structural template in Revit...
I am running with Windows 10... but it was running and working before I had installed the SP4 update.
Gustavo
Replies (16)
Message 2 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
File please.
Rafal Gaweda
Message 3 of 17
Dear Rafal,
I had to copy the DRevit2Robot.dll file again to as bellow, from:
c:\Program Files\Common Files\Autodesk Shared\Extensions 2016\Modules\RSA\DRevit2Robot\
to:
c:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2016\System\Exe\
Gustavo
Message 4 of 17
Hi Gustavo
Still facing the same problem ....  UNKNOWN RUNTIME ERROR
kindly advice
Sebastiao
Message 5 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach your Revit model? Is it for 2016 version of both programs or other?
Artur Kosakowski
Message 6 of 17
Hi there,
I'm facing the same problem. I copied the file as you specified. And unfortunately, this solution has not worked.
Could you please help me if there is any other solution?
Thanks for your times.
Message 7 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Artur Kosakowski
Message 8 of 17
Hi @Artur.Kosakowski
I'm attaching the file.
Message 9 of 17
Message 10 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
I do not see any issue.
I am using Revit 2018.2 and Robot 2018 HF2
Robot file attached
Rafal Gaweda
Message 11 of 17
did you solve this problem?
Message 12 of 17
Message 13 of 17
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach the Robot (and Revit model if used) and make a movie showing the steps to follow to reproduce this situation?
You can use Sreeencast which is freeware application to make the movie.
Artur Kosakowski
Message 14 of 17
amitvaghela19
Same problem just  " Unknown run-time error when integrating Revit 2017 to Robot 2019".Error come after installing revit extention 2017
Message 15 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi   @amitvaghela19
Integration should work for the same version number software.
Robot 2017 - Revit 2017
Robot 2019 - Revit 2019
Rafal Gaweda
Message 16 of 17
amitvaghela19
Hi @Rafal.Gaweda
It works for Revit 2017- robot 2019.
Because of some bugs, it won't work yesterday but after reinstalling both software it works very smoothly with Revit extension and CSIXRevit.
But if error comeback in the future then I will think about it.
Thank you
Message 17 of 17
你好,你问题解决了吗? 我也遇到了同样问题,从robot 到Revit 出现run time error
