Help with spread footing dimensions
I'm trying to design a spread footing with the RC elements button (RC design), and the distance e2 between columns taken by RSA is always constant at 1.22 meters (see image 1). In addition, the actual distance when selecting nodes 1 and 3 (supports, see image 2) is 6 meters (for this case) and there is no possibility to modify it. The Global Axis change too between the RC design mode and de General Structure View.
How can I fix this so that the distance between the columns in the spread footing is the real (6 meters) instead of 1.22 meters?
I've used the RC design for isolated footing and everythig was perfect. Can anyone help me, please?
The .rtd file attached is just an application of the same problem in a more complicated calculation model, whose size was too large to attach.
Thanks in advance,
Juan
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Thank you!!
