I have another problem about values of reactions wich shows 'Aucun"
@genieyas Artur Kosakowski marked post as the solution. If it did not work as an answer, please post your reply in this thread so that I can unmark the solution.
Solved by Refaat. Go to Solution.
Same thing happens here when asking for all simple cases+combinations. But it works when asking only for combinations
probably some memory problem . Maybe official support can explain better
Rafael Medeiros
Think You Mr Refaat for the information
But even if i deselect the case Bc i always have the results of somme reactions "Aucun" (See attached capture)
Think You
Mr Refaat
I can see also that no reactions values are imported from robobat for strip foundation calculation (see attached 😞 All values équal to zéro
Could you pls help me to solve this issue
Sincerly
Hi @genieyas
Try to delete all the load cases and the combination cases then select the combination cases and the load cases except the moving load case (3- BC).
Then easily to get the results for both load cases and combination load cases (as in the captures of my previous post of this thread).
Refaat
Hello Mr Artur.Kosakowski
The problem is solved think you very much
I will try now calculationg my strip foundation
i hope it works now
Sincerly
It reamin one more problem
The calculation of reinforcement of my strip foundation gives me big frame (see attached pls)
Also i can see load case 0 whene askin for srip foundation reinforcement
Sincerly
Hello Mr
I think this frame is exagerated.
I take the same combinations used by robobat to calculate the spread footing in the modele (version used Robobat 2018; see 1st attached pls), and i go to Robobat 2014 in alone modele of spread footing, after calculation: the results are differents (See attached two)
Sincerly
The results are different when i use robobat 2014, in fact i fellow this steps: ( FYI: The model i use is Robobat 2018)
- i Take all cominations imported from robobat from the "Note de calcul" (see 1er attached) (Slidings, soil capacity....)
- I enter this combinations (4 combinations) in the alone model of reinforcement of spread footing at Robobat 2014
- I check the results : They are differents:
Sincerly
Hi @genieyas
I opened the foundation as defined in RSA 2014 in RSA 2018 and locked all dimensions. Then I calculated it -> no errors reported which means that most likely the foundation you recreated in RSA 2018 is not exactly the same as the original one you tried to design in RSA 2018. The same for unlocked dimensions.
I think that the loads are the same in the two models (2018 and 2014), the only difference is the soil (angle of friction):
- in the 2018 (Module alone): The angle of friction is 0.58 (see attached2)
- In the 2018 (results imported from the modele): The angle of friction is 0.30 (see attached 1)
Even if i use the same soil
Why the results are differents?
Sincerly
- in the 2018 (Module alone): The angle of friction is 0.58 (see attached1)
- In the 2018 (results imported from the modele): The angle of friction is 0.30 (see attached 2)
Sincerly
I hope my question is understandable, and excuse me my english is not good
If you don't understad some thin please ask me
Sincerly
