Soil Springs on either side of the panel
sindhu.vaddagerenagaraja
Is there  a way to apply soil springs on either side of the panel/wall when the soil spring values are different?
@okapawal @Artur.Kosakowski @Rafal.Gaweda
okapawal
@sindhu.vaddagerenagaraja
You may define nonlinear planar support with different elasticity  on positive and negative direction.
Waldemar Okapa
Software Quality Assurance & Testing Engineer
But how can you apply 2 support conditions to a single node? I don't think so it is possible. Please check again and let me know.
But how can you apply 2 support conditions to a single node? I don't think so it is possible. Please check again and let me know. @okapawal
okapawal
There can be only single support in each node.  But it has different elasticity for displacement in positive or negative direction of chosen XYZ axis.
Keep in mind that nonlinear elasticity value refers to each node, so it depends on the mesh size.
Waldemar Okapa
