Message 1 of 8
02:14 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there,
As the title suggests, the software allows me to pull in design elements into the provided reinforcement module. However, when I attempt to run the calculation, the software just freezes and then crashes. If select the generate drawings option before running the calculation, then the windows installer dialog box opens, nothing is installed but then the software crashes.
Any suggestions as to why this occurs? I saw a similar post which suggests it may have something to do with having Revit on the machine, does that mean I can only run RC calculations with Revit uninstalled?
