Hi @Anonymous
RSA cannot generate drawings like the one you attached. Such functionality used to be available in ASD Reinforcement which you could export information from RSA to. You may also consider saving reinforcement zones as dxf/dwg and making final drawings in Revit based on the information from these dxf/dwg files.
