structure floor view help artur////how to view///
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
RSA cannot generate drawings like the one you attached. Such functionality used to be available in ASD Reinforcement which you could export information from RSA to. You may also consider saving reinforcement zones as dxf/dwg and making final drawings in Revit based on the information from these dxf/dwg files.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
