Snapping to imported dwg. file intersection lines
skellyRSA2023
skellyRSA2023
When importing a dwg. format file into robot, it is difficult to snap to an intersection point on the imported dwg. file, I can snap to a endpoint of a line or midpoint however it does not seem to snap to an intersection point on the imported dwg. is there a method of doing this, see attached pdf.
Simon.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @skellyRSA2023
The best option is to intersect the lines in the dwg first.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Mohammed_Ata
Please, Mr. Artur
We have sent tens of ideas for development team to improve completely the integration with AutoCAD.
Hope the team is really working on it.
Please.
Please.
Robot and AutoCAD are for Autodesk and the integration is too poor.
