I've seen some tutorials and videos showing how to model a waffle slab, but they don't discuss how to create "solid heads" in the areas near columns, where shear is maximum. Is it possible to do so? Note that the dimensions of the solid heads must match the grid of the waffle slab ribs, as they are achieved by removing the corresponding hollow blocks near the columns.
Also, can I expect to get a good reinforcement design, or maybe some weird/abrupt changes between the ribbed and the solid areas could be generated by the software?
