I am trying to design a slotted steel structure but cannot decide which type of release to use.
Those parts are pinned for the XY but released for Z direction.
I designed the frame with RSA as follows:
I also defined a new release and applied for both slotted box sections:
But when I perform analysis I am getting instability 2 type warning:
Is there a way to design slotted type release with RSA? I tried to add a roller like support XY pinned and Z released still getting the same message. And it looks like there is movement along X even the X direction is not released.
Solved by Simau. Go to Solution.
Try this
M. Agayr
According to the nestings in the image below, mx my and mz bending moment will be transfered
M. Agayr
Yes, it is possible to test the options you propose, but IMHO more complicated to apply.
M. Agayr
