Robot Structural Analysis Forum
Welcome to Autodeskā€™s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Showing results forĀ
Did you mean:Ā
Slotted Steel Box Section Release
5 REPLIES 5
umut.akparlar
175 Views, 5 Replies
I am trying to design a slotted steel structure but cannot decide which type of release to use.
Those parts are pinned for the XY but released for Z direction.
I designed the frame with RSA as follows:
I also defined a new release and applied for both slotted box sections:
But when I perform analysis I am getting instability 2 type warning:
Is there a way to design slotted type release with RSA? I tried to add a roller like support XY pinned and Z released still getting the same message. And it looks like there is movement along X even the X direction is not released.
5 REPLIES 5
Simau
in reply to: umut.akparlar
Hi@umut.akparlar
Try this
M. Agayr
umut.akparlar
in reply to: Simau
Thank you for your answer @Simau .
There will be no moment transfer between those two members so if I uncheck Rxyz it won't reflect the real model?
Simau
@umut.akparlar
According to the nestings in the image below, mx my and mz bending moment will be transfered
M. Agayr
umut.akparlar
in reply to: Simau
That makes sense, thank you @Simau .
Do you also think compatible node between those members also work?
Or nonlinear hinges ?
Simau
@umut.akparlar
Yes, it is possible to test the options you propose, but IMHO more complicated to apply.
M. Agayr
Technology Administrators
