I'm calculating a slab on grade. Although it has just compression loads, calculation doesn't converge. I think it has no sense. What is wrong?
Thanks.
@Anonymous Artur Kosakowski edited the topic from 'Slab design / support rigidity' for better findability.
Solved by Artur.Kosakowski. Go to Solution.
Hi @Anonymous
As far as I can see you have also moments which may actually cause uplift. Try to set the nonlinear analysis parameters as below:
Hi Artur,
I have set this parameters previously but calculation doesn´t converge.Furthermore ,I have increased the slab thickness up to 120 mm and it doesn´t work anyway.
Hi Artur,
Structural model is attatched.
Anyway I am testing another model with rigid links in the base of the pedestals as you can see in the picture attatched. In that way calculation seems to be ok .
Hi @Anonymous
All combinations converge with slightly increased tolerances.
Hi Artur
Sorry, but I don't fin what changes have your made in the solved model, tolerances seems to be the same.
On the other hand , do you think that the other solution with rigid links could be right as well?.
Hi @Anonymous
Yes, I think it is correct too.
