Simulate retrofitted column
EY23
Message 1 of 9
EY23
hi all,
Is there any way to simulate retrofitted column with steel bars?
I tried to use composite column section but i got the same results. (with and without reinforcement)
thanks
Replies (8)
Message 2 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @EY23
What results do you mean exactly?
Artur Kosakowski
Message 3 of 9
EY23
I have a concrete column retrofitted,
I'am trying to get the allowable loads.
I draw the column old, the additional casing and the vertical reinforcement in it using the composite section module,
then compare it with the same section but without reinforcement.
I got the same deflection results in both sections.
Message 4 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @EY23
Could you attach the model with these two columns side by side as well as the *.sec file with the shape of the composite one?
Artur Kosakowski
Message 5 of 9
EY23
attached file and sections
Message 6 of 9
EY23
attached model
Message 7 of 9
EY23
attached sections...file is in a separate reply due to uploading problem
Message 8 of 9
EY23
all in zip file
Message 9 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @EY23
The sec file for the rebar section is incorrect. I'm attaching the modified one which I used in my test example.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
