Load overlap, automatic panel creation and DSC algorithm prompt
I have several happenings when I click on calculate:
1) I cannot progress unless I select DSC alogorithm
2) Panel previously deleted is recreated automatically and I get this warning: “The load has not been distributes correctly, there are not objects or elements carrying the load overlap”
3) Instability type 2 and 3.
Could you see my file please, I can’t find the cause.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
You can, this is just the suggestion.
This is because you defined the surface load on the contour above the panel.
You cannot have pinned connections for cantilevers (consider that the tension only bars doesn't work under compression).
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
