Separate structure
Separate structure
peterkamal91
Separate structure
peterkamal91
Hello every one
i got error separate structure and i don't know why or how can i find that separate structure, can any one help ?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
peterkamal91
Thank you Artur for help
I have tried to ensure the 2 objects are in contact, but I faced the same error.
Please advise.
@Artur.Kosakowski
Could you please have a look at the attached file.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Please check https://forums.autodesk.com/t5/robot-structural-analysis-forum/seperate-structure-circular-volumetri...
Please DO NOT post the same issue in multiple topics on the Robot forum as it makes following these threads very difficult. I do appreciate your understanding in this matter. Thank you.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
