Separate structure
peterkamal91
Separate structure
peterkamal91
Hello every one
i got error separate structure and i don't know why or how can i find that separate structure, can any one help ?
Artur.Kosakowski
Autodesk Support
Autodesk Support
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
peterkamal91
Thank you Artur for help
I have tried to ensure the 2 objects are in contact, but I faced the same error.
Please advise.
@Artur.Kosakowski
Could you please have a look at the attached file.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Please check https://forums.autodesk.com/t5/robot-structural-analysis-forum/seperate-structure-circular-volumetric-object/m-p/8127421#M68984
Please DO NOT post the same issue in multiple topics on the Robot forum as it makes following these threads very difficult. I do appreciate your understanding in this matter. Thank you.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
