Dear all,
I have recently started using Robot and have encountered a separate structure problem which I cannot trouble shoot. I have basically modelled part of a flat slab which I would like to analyse supported on columns and and internal wall which I have modelled with a pinned reaction support. I somehow keep on getting a separate structure problem when carrying out calculations. I have checked the separate structures in my nodes selection group tab and from what I can understand, the columns and the slab are being considered as separate structures by Robot. Any idea how I can get round this problem and could you please explain to me where my modelling mistake is? Please find attached a model of what I have described above.
Solved by Rafal.Gaweda. Go to Solution.
Columns 20 21 36 37 are not connected with slab.
Columns 20 21 are not connected to each other.
Make BIG ZOOM near nodes 2 3 27
hi Rafal,
I got same issue,
but mine is a big different, looking on the robot model it works. but every time i run the analysis it shows separate structure. and when I go and check which node is separated it highlight all my nodes.
thank you,
mark
