Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Separate Structure Problem
3 REPLIES 3
552 Views, 3 Replies
Dear all,
I have recently started using Robot and have encountered a separate structure problem which I cannot trouble shoot. I have basically modelled part of a flat slab which I would like to analyse supported on columns and and internal wall which I have modelled with a pinned reaction support. I somehow keep on getting a separate structure problem when carrying out calculations. I have checked the separate structures in my nodes selection group tab and from what I can understand, the columns and the slab are being considered as separate structures by Robot. Any idea how I can get round this problem and could you please explain to me where my modelling mistake is? Please find attached a model of what I have described above.
3 REPLIES 3
Rafal.Gaweda
Columns 20 21 36 37 are not connected with slab.
Columns 20 21  are not connected to each other.
Make BIG ZOOM near nodes 2 3 27
Rafal Gaweda
markjvlampad
in reply to: Rafal.Gaweda
hi Rafal,
 I got same issue,
but mine is a big different, looking on the  robot model it works. but every time i run the analysis it shows separate structure. and when I go and check which node is separated it highlight all my nodes.
thank you,
mark
Rafal.Gaweda
in reply to: markjvlampad
Mark,
File please.
Rafal Gaweda
