I need to check Sensitivity coefficient ''theta'' EC8. I have a simple steel structure..4 columns and 4 primary beams + purlins. It is for a parking bay. How can I get out the reduced forces? I would know how Can I see in robot the Vtot of this formula:
If it is possible. Or if there is an automatic way to check Theta coefficient directly with the software.
Many Thanks,
Michele
Solved by Michele100100. Go to Solution.
Solved by Simau. Go to Solution.
Use Structure story then Results>Diagram for builings you'll get what you need to calculate Theta
M. Agayr
many thanks, is exactly what I was looking for, but the only result that I can get out in my model is the drif dr.
Ptot and Vtot are not shown.
What can be the problem??
Ptot = Fz
Vtot = Fx or Fy depending on seismic direction
M. Agayr
Not forces are shown in my model, whatever combination I select, I cant see forces. If I see diagram, everything is shown, but Diagram for building is not working. I dont know why.
Many thanks
Could you share your model
Zip it before.
M. Agayr
You must create "story" first
Model attached
M. Agayr
