I Modelled a small building using the 2020 version of Robot, and the uplift calculation for self-weight is not converging, dead and live loads converging, Opened the same file with the 2015 version (the last stable version of robot IMHO) and all static loads converged including self-weight. Work analysis and nonlinear parameter used in both version are the same. Can anyone help with this, I'm really looking forward to using the latest version. I've attached the model and a calculation screen shot. Thanks
Solved by Rafacascudo. Go to Solution.
I cannot help you on why 2015 is better than 2020 regarding converging ability , but you can make it work on 2020 version using these non linear parameters
Rafael Medeiros
Thank you very much, I'll be more careful in the future while setting nonlinear parameters.
As a follow up on this, I've added the proper combinations, where the self-weight is included convergence wasn't achieved even with the parameters you kindly provided, changed the parameters again to get it to work.
I think Autodesk should be made aware of this, self-weight case should converge with the default parameters, just keep the same 2015's calculation engine, is this too much to ask.
