Seismic load mass conversion
mgaafar
mgaafar
Hi, I was designing a multi-storey structure in RSA, and I was using the equivelant lateral force method for ASCE 7-10.
Now I know that RSA takes the selfweight by default in the seismic calculations and any other added loads in the "Load to mass Conversion" tab.
in my case, I need RSA to ignore the selfweight and use only specified loads in the "Load to mass Conversion" tab.
How can I do that?
Replies (9)
dimogrec
Maybe defining a material with no weight should work...
StefanoPasquini6790
Hi, quickly and easy.
Create a load case called "self weight_seismic" and one other called "self weight_non seismic". In the first one assign self weight load type selecting, from load table, part of the structure and assigning the list of the bars, panels ecc that compose the seismic mass. Otherwise selct all the non seismic element and assign it to self weight_non seismic load condition.
When you run the modal analysis you have to ignore density and, in the load to mass conversion table, select the self weight_seismic and add to conversion.
This procedure can be used also for dead loads and variable loads.
In the first time you made this I suggest you to check it manually, define first the effective seismic mass than check the robot value in the table. I make it everyday and it's more difficult to explain that to do it.
Hope I help you, greetings.
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
mgaafar
Thanks, So when you say that I have to ignore density, does this mean that I have to create a material with Zero density or there is another way to ignore density. I know you can check the "ignore density" in the modal analysis but there is no such option in the equivelant lateral force window option.
dimogrec
@mgaafar wrote:
.... I know you can check the "ignore density" in the modal analysis but there is no such option in the equivelant lateral force window option.
That's the reason I suggested you to set a zeo value on density (weight) of your material. ( You don't have to define new material just edit the excisting one from Tools->job preferences->material->modification.. .)  I don't know if there's an other way for equivalent lateral force method
If "ignore density" tab was available you could you some other tricks as Stefano proposed.
Good mornign ,
I am trying to run a modal analysis in Costa Rica Central america
I have an acceleration spectrum loaded but when run analysys forces and displacement become all zero
The  Question is :
To run the analsys do I have to create an additional node at gravitational structure center , assign mass to the the node ?
Is there any mass source node in Robot ?
Thank you very much for your kind answer
Rafal.Gaweda
Autodesk Support
Autodesk Support
File please.
Rafal Gaweda
Herein you will find , file and spectrum
Rafal.Gaweda
Autodesk Support
Autodesk Support
 If your spectrum is correct (max acceleration = 0,5m/s2), and if mass is correct (almost 1,45 mass of self weight (1.0 sw mass from modal caase defintion + 0,45 of case 18 load to mass coversion) + 0,45 load to mass of case 2) so the results are also correct but to see them you have to change scale coeff and units
undefined
Rafal Gaweda
If I can recall, the SW can be ignored using ignore density option in the Modal Analysis. Then Use Convert Loads to masses. Don't use load to masses if you did not uncheck this option or your seismic mass will double
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
